How to measure Rout & Rin using Cadence Analog Design?
richloo
Full Member level 1
Full Member level 1
Isolated Island
input resistance measure breadboard
Hi, i am new to cadence software. Can anyone tell me the step to measure input resistance and output resistance of a circuit? Thanks in advance!
analog design using cadence
Using calculator. Divide VS/IS for DC analysis, VF/IF for AC analysis, VT/IT for transient analysis. Then plot it.
measuring output impedance in cadence
There is no point in discussing input/ouput resistance (better term would be impedance) in DC. So it is AC.
I am not so familiar with what Cadence you are reffering but if you are using OrCAD you can absolutely you can make input/output admitance/impedance vs. frequency.
Please add more info and I guide how. Would be a lot easier in Ansoft Designer or ADS but yes! you can in Cadence OrCAD.
What version?
cadence + input + output impedance
In any of the case of what Cadence Product you have here is how you guys can do in cadence OrCAD.
Menu "Spice"
See pictures. Simulation must be AC sweep.
how to measure the output impedance orcad
for example; i want to measure the output impedence of bias current source which is made of NMOS, what can i do?
measuring input impedance in orcad
As the case i wan to measure i/p and o/p impedance of an amplifier... how can i do that? i mean in Cadence IC50. Or else i have to goto result browser to find the rout for each transistor and write out all the nodal equation... any other fast method?
plot output impedance cadence
I do not know in Cadence IC50. I have never used this product. Sorry guys.
What I said for the above is for OrCAD.
I can tell you in also in A g i l e n t A DS and Ansoft Designer.
measure input impedance cadence
(1). DC Rin and Rout: as what is said in the textbook, using a test voltage source to get the DC current, then R=V/I...
(2). Small signal Zin and Zout: just perform the S-Parameter simulation, no matter the simulator is Cadence or ADS.
Hope this helps.
Ruri
Reactions: himansg
    richloo
    himansg
Also from the calculator u can draw the real and imaginary parts, each in a separate curve
    richloo
