Jkarir
Newbie level 6
Yesterday i had exam at electronics and i failed at it, the reason was i didn't know how to solve correctly electric circuits. Our exam contains 2 theories and 2 circuits electric problem, one is a continuous circuit and the other a alternative circuit.
We usually solve circuits with Kirchoff Laws/The Branch-Current Method.
But at the first step i did something that i didn't quite understand.
Below is a photo how the circuit was looking, someone told that all the elements which are on the conductor line must be cut from the circuit and also the circuit must be disconnected from the source, after that i should apply the The Branch-Current Method/Kirchoff.
I started all wrong resolving the circuit for the fact i didn't know to disconnect and cut what?? i still don't know how the circuit will look after i do this in order to solve it:shock:
