Test bench question
Kgonz
Newbie level 5
Hello I am trying to create a testbench for this VHDL code of an SPI slave that I found online for verification and so that i can implement it into a project that I'm working on. I've gotten my testbench to compile and run and to drive signals but the data transfer and all the MOSI and MISO lines aren't working the way the author verified it in the website. any help is appreciated. the author verified through the website so I know the reason it doesn't work has to do with the testbench i wrote
this is a link to the website where I got the SPI slave
https://forum.digikey.com/t/spi-slave-vhdl/12721
SPI SLAVE
  1. --------------------------------------------------------------------------------
  2. --
  3. -- FileName: spi_slave.vhd
  4. -- Dependencies: none
  5. -- Design Software: Quartus Prime Version 17.0.0 Build 595 SJ Lite Edition
  6. --
  7. -- HDL CODE IS PROVIDED "AS IS." DIGI-KEY EXPRESSLY DISCLAIMS ANY
  8. -- WARRANTY OF ANY KIND, WHETHER EXPRESS OR IMPLIED, INCLUDING BUT NOT
  9. -- LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
  10. -- PARTICULAR PURPOSE, OR NON-INFRINGEMENT. IN NO EVENT SHALL DIGI-KEY
  11. -- BE LIABLE FOR ANY INCIDENTAL, SPECIAL, INDIRECT OR CONSEQUENTIAL
  12. -- DAMAGES, LOST PROFITS OR LOST DATA, HARM TO YOUR EQUIPMENT, COST OF
  13. -- PROCUREMENT OF SUBSTITUTE GOODS, TECHNOLOGY OR SERVICES, ANY CLAIMS
  14. -- BY THIRD PARTIES (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF),
  15. -- ANY CLAIMS FOR INDEMNITY OR CONTRIBUTION, OR OTHER SIMILAR COSTS.
  16. --
  17. -- Version History
  18. -- Version 1.0 7/5/2012 Scott Larson
  19. -- Initial Public Release
  20. -- Version 1.1 11/27/2012 Scott Larson
  21. -- Added an asynchronous active low reset
  22. -- Version 1.2 5/7/2019 Scott Larson
  23. -- Modified architecture slightly to make it synthesizable with more tools
  24. --
  25. --------------------------------------------------------------------------------
  26. LIBRARY ieee;
  27. USE ieee.std_logic_1164.all;
  28. USE ieee.std_logic_arith.all;
  29. ENTITY spi_slave IS
  30. GENERIC(
  31. cpol : STD_LOGIC := '0'; --spi clock polarity mode
  32. cpha : STD_LOGIC := '0'; --spi clock phase mode
  33. d_width : INTEGER := 8); --data width in bits
  34. PORT(
  35. sclk : IN STD_LOGIC; --spi clk from master
  36. reset_n : IN STD_LOGIC; --active low reset
  37. ss_n : IN STD_LOGIC; --active low slave select
  38. mosi : IN STD_LOGIC; --master out, slave in
  39. rx_req : IN STD_LOGIC; --'1' while busy = '0' moves data to the rx_data output
  40. st_load_en : IN STD_LOGIC; --asynchronous load enable
  41. st_load_trdy : IN STD_LOGIC; --asynchronous trdy load input
  42. st_load_rrdy : IN STD_LOGIC; --asynchronous rrdy load input
  43. st_load_roe : IN STD_LOGIC; --asynchronous roe load input
  44. tx_load_en : IN STD_LOGIC; --asynchronous transmit buffer load enable
  45. tx_load_data : IN STD_LOGIC_VECTOR(d_width-1 DOWNTO 0); --asynchronous tx data to load
  46. trdy : BUFFER STD_LOGIC := '0'; --transmit ready bit
  47. rrdy : BUFFER STD_LOGIC := '0'; --receive ready bit
  48. roe : BUFFER STD_LOGIC := '0'; --receive overrun error bit
  49. rx_data : OUT STD_LOGIC_VECTOR(d_width-1 DOWNTO 0) := (OTHERS => '0'); --receive register output to logic
  50. busy : OUT STD_LOGIC := '0'; --busy signal to logic ('1' during transaction)
  51. miso : OUT STD_LOGIC := 'Z'); --master in, slave out
  52. END spi_slave;
  53. ARCHITECTURE logic OF spi_slave IS
  54. SIGNAL mode : STD_LOGIC; --groups modes by clock polarity relation to data
  55. SIGNAL clk : STD_LOGIC; --clock
  56. SIGNAL bit_cnt : STD_LOGIC_VECTOR(d_width+8 DOWNTO 0); --'1' for active transaction bit
  57. SIGNAL wr_add : STD_LOGIC; --address of register to write ('0' = receive, '1' = status)
  58. SIGNAL rd_add : STD_LOGIC; --address of register to read ('0' = transmit, '1' = status)
  59. SIGNAL rx_buf : STD_LOGIC_VECTOR(d_width-1 DOWNTO 0) := (OTHERS => '0'); --receiver buffer
  60. SIGNAL tx_buf : STD_LOGIC_VECTOR(d_width-1 DOWNTO 0) := (OTHERS => '0'); --transmit buffer
  61. BEGIN
  62. busy <= NOT ss_n; --high during transactions
  63. --adjust clock so writes are on rising edge and reads on falling edge
  64. mode <= cpol XOR cpha; --'1' for modes that write on rising edge
  65. WITH mode SELECT
  66. clk <= sclk WHEN '1',
  67. NOT sclk WHEN OTHERS;
  68. --keep track of miso/mosi bit counts for data alignmnet
  69. PROCESS(ss_n, clk)
  70. BEGIN
  71. IF(ss_n = '1' OR reset_n = '0') THEN --this slave is not selected or being reset
  72. bit_cnt <= (conv_integer(NOT cpha) => '1', OTHERS => '0'); --reset miso/mosi bit count
  73. ELSE --this slave is selected
  74. IF(rising_edge(clk)) THEN --new bit on miso/mosi
  75. bit_cnt <= bit_cnt(d_width+8-1 DOWNTO 0) & '0'; --shift active bit indicator
  76. END IF;
  77. END IF;
  78. END PROCESS;
  79. PROCESS(ss_n, clk, st_load_en, tx_load_en, rx_req)
  80. BEGIN
  81. --write address register ('0' for receive, '1' for status)
  82. IF(bit_cnt(1) = '1' AND falling_edge(clk)) THEN
  83. wr_add <= mosi;
  84. END IF;
  85. --read address register ('0' for transmit, '1' for status)
  86. IF(bit_cnt(2) = '1' AND falling_edge(clk)) THEN
  87. rd_add <= mosi;
  88. END IF;
  89. --trdy register
  90. IF((ss_n = '1' AND st_load_en = '1' AND st_load_trdy = '0') OR reset_n = '0') THEN
  91. trdy <= '0'; --cleared by user logic or reset
  92. ELSIF(ss_n = '1' AND ((st_load_en = '1' AND st_load_trdy = '1') OR tx_load_en = '1')) THEN
  93. trdy <= '1'; --set when tx buffer written or set by user logic
  94. ELSIF(falling_edge(clk)) THEN
  95. IF(wr_add = '1' AND bit_cnt(9) = '1') THEN
  96. trdy <= mosi; --new value written over spi bus
  97. ELSIF(rd_add = '0' AND bit_cnt(d_width+8) = '1') THEN
  98. trdy <= '0'; --clear when transmit buffer read
  99. END IF;
  100. END IF;
  101. --rrdy register
  102. IF((ss_n = '1' AND ((st_load_en = '1' AND st_load_rrdy = '0') OR rx_req = '1')) OR reset_n = '0') THEN
  103. rrdy <= '0'; --cleared by user logic or rx_data has been requested or reset
  104. ELSIF(ss_n = '1' AND st_load_en = '1' AND st_load_rrdy = '1') THEN
  105. rrdy <= '1'; --set when set by user logic
  106. ELSIF(falling_edge(clk)) THEN
  107. IF(wr_add = '1' AND bit_cnt(10) = '1') THEN
  108. rrdy <= mosi; --new value written over spi bus
  109. ELSIF(wr_add = '0' AND bit_cnt(d_width+8) = '1') THEN
  110. rrdy <= '1'; --set when new data received
  111. END IF;
  112. END IF;
  113. --roe register
  114. IF((ss_n = '1' AND st_load_en = '1' AND st_load_roe = '0') OR reset_n = '0') THEN
  115. roe <= '0'; --cleared by user logic or reset
  116. ELSIF(ss_n = '1' AND st_load_en = '1' AND st_load_roe = '1') THEN
  117. roe <= '1'; --set by user logic
  118. ELSIF(falling_edge(clk)) THEN
  119. IF(rrdy = '1' AND wr_add = '0' AND bit_cnt(d_width+8) = '1') THEN
  120. roe <= '1'; --set by actual overrun
  121. ELSIF(wr_add = '1' AND bit_cnt(11) = '1') THEN
  122. roe <= mosi; --new value written by spi bus
  123. END IF;
  124. END IF;
  125. --receive registers
  126. --write to the receive register from master
  127. IF(reset_n = '0') THEN
  128. rx_buf <= (OTHERS => '0');
  129. ELSE
  130. FOR i IN 0 TO d_width-1 LOOP
  131. IF(wr_add = '0' AND bit_cnt(i+9) = '1' AND falling_edge(clk)) THEN
  132. rx_buf(d_width-1-i) <= mosi;
  133. END IF;
  134. END LOOP;
  135. END IF;
  136. --fulfill user logic request for receive data
  137. IF(reset_n = '0') THEN
  138. rx_data <= (OTHERS => '0');
  139. ELSIF(ss_n = '1' AND rx_req = '1') THEN
  140. rx_data <= rx_buf;
  141. END IF;
  142. --transmit registers
  143. IF(reset_n = '0') THEN
  144. tx_buf <= (OTHERS => '0');
  145. ELSIF(ss_n = '1' AND tx_load_en = '1') THEN --load transmit register from user logic
  146. tx_buf <= tx_load_data;
  147. ELSIF(rd_add = '0' AND bit_cnt(7 DOWNTO 0) = "00000000" AND bit_cnt(d_width+8) = '0' AND rising_edge(clk)) THEN
  148. tx_buf(d_width-1 DOWNTO 0) <= tx_buf(d_width-2 DOWNTO 0) & tx_buf(d_width-1); --shift through tx data
  149. END IF;
  150. --miso output register
  151. IF(ss_n = '1' OR reset_n = '0') THEN --no transaction occuring or reset
  152. miso <= 'Z';
  153. ELSIF(rising_edge(clk)) THEN
  154. IF(rd_add = '1') THEN --write status register to master
  155. CASE bit_cnt(10 DOWNTO 8) IS
  156. WHEN "001" => miso <= trdy;
  157. WHEN "010" => miso <= rrdy;
  158. WHEN "100" => miso <= roe;
  159. WHEN OTHERS => NULL;
  160. END CASE;
  161. ELSIF(rd_add = '0' AND bit_cnt(7 DOWNTO 0) = "00000000" AND bit_cnt(d_width+8) = '0') THEN
  162. miso <= tx_buf(d_width-1); --send transmit register data to master
  163. END IF;
  164. END IF;
  165. END PROCESS;
  166. END logic;
SPI Slave TestBench
  1. library IEEE;
  2. use IEEE.Std_logic_1164.all;
  3. entity spi_slavetestbench is
  4. end spi_slavetestbench;
  5. architecture bench of spi_slavetestbench is
  6. component spi_slave
  7. port
  8. (sclk, reset_n,ss_n,mosi,rx_req,st_load_en,st_load_trdy,st_load_rrdy,st_load_roe,tx_load_en: in std_logic;
  9. tx_load_data : IN STD_LOGIC_VECTOR;
  10. rx_data : OUT STD_LOGIC_VECTOR;
  11. busy, miso : out std_logic;
  12. trdy,rrdy,roe : BUFFER std_logic
  13. );
  14. end component;
  15. constant d_width : INTEGER := 8;
  16. signal sclk, reset_n,ss_n,mosi,rx_req,st_load_en,st_load_trdy,st_load_rrdy,st_load_roe,tx_load_en: std_logic;
  17. signal busy, miso: std_logic;
  18. signal tx_load_data: STD_LOGIC_VECTOR(d_width-1 DOWNTO 0);
  19. signal rx_data : STD_LOGIC_VECTOR(d_width-1 DOWNTO 0) := (OTHERS => '0');
  20. signal trdy,rrdy,roe : std_logic;
  21. constant clock_period: time := 10 ns;
  22. SIGNAL mode : STD_LOGIC; --groups modes by clock polarity relation to data
  23. SIGNAL clk : STD_LOGIC; --clock
  24. SIGNAL bit_cnt : STD_LOGIC_VECTOR(d_width+8 DOWNTO 0); --'1' for active transaction bit
  25. SIGNAL wr_add : STD_LOGIC; --address of register to write ('0' = receive, '1' = status)
  26. SIGNAL rd_add : STD_LOGIC; --address of register to read ('0' = transmit, '1' = status)
  27. SIGNAL rx_buf : STD_LOGIC_VECTOR(d_width-1 DOWNTO 0) := (OTHERS => '0'); --receiver buffe SIGNAL tx_buf : STD_LOGIC_VECTOR(d_width-1 DOWNTO 0) := (OTHERS => '0'); --transmit buffer
  28. signal stop_the_clock: boolean;
  29. begin
  30. DUT : entity work.spi_slave
  31. port map (
  32. sclk => sclk,
  33. reset_n => reset_n,
  34. ss_n => ss_n,
  35. mosi => mosi,
  36. rx_req => rx_req,
  37. st_load_en => st_load_en,
  38. st_load_trdy => st_load_trdy,
  39. st_load_rrdy => st_load_rrdy,
  40. st_load_roe => st_load_roe,
  41. tx_load_en => tx_load_en,
  42. tx_load_data => tx_load_data,
  43. rx_data => rx_data,
  44. busy => busy,
  45. trdy => trdy,
  46. rrdy => rrdy,
  47. roe => roe,
  48. miso => miso
  49. );
  50. STIM: process -- stimulus
  51. begin
  52. wait for clock_period;
  53. reset_n <= '1';
  54. ss_n <= '1';
  55. wait for clock_period;
  56. reset_n <= '1';
  57. ss_n <= '0';
  58. tx_load_en <= '1';
  59. tx_load_data <= "10101010";
  60. wait for clock_period*40;
  61. stop_the_clock <= true;
  62. wait;
  63. end process;
  64. process -- clock generation
  65. begin
  66. while not stop_the_clock loop
  67. clk <= '0';
  68. wait for clock_period / 2;
  69. clk <= '1';
  70. wait for clock_period / 2;
  71. end loop;
  72. wait;
  73. end process;
  74. process -- clock generation
  75. begin
  76. while not stop_the_clock loop
  77. sclk <= '0';
  78. wait for clock_period / 2;
  79. sclk <= '1';
  80. wait for clock_period / 2;
  81. end loop;
  82. wait;
  83. end process;
  84. end;
waveforms
Aside from the fact that I'm not going to wade through 500 lines of your unformatted, uncommented code, I would suggest that you are not initializing something properly. It looks like you never assert your reset_n.
In the future, provide a little more information. Just saying "it isn't working" and throwing 500 lines of code at us is not a good way to get any help. Tell us what you're expecting vs. what you're seeing.
