PIC16F877 Development Board ?
SphinX
Advanced Member level 3
EGYPT
pic16f877 development board
I want to build one.
Thanx
pic development board protel
Take a look at the the PrimeKit PIC Development Board II.
or
PrimeKit PIC DevBoard II is a development board for Microchip® PICmicro®
micro-controllers, and programming of Microchip® PICmicro® microcontrollers
can be learned, by exploring the 12C/Fxxx, 16C/Fxxx, and 18C/Fxxx families.
PrimeKit PIC DevBoard II configuration is done by Jumpers, that allow
activation/deactivation of all peripherals. All peripherals that share the
same micro-controller BUS, are in parallel. If in need of any outside
component testing, the provided Proto-board may be used, as well as the
flat-cable sockets.
The Radio Transceiver, USB and Ethernet modules are optional, although they
may be supplied with the PrimeKit PIC DevBoard II.
You may find this on the webpage, but here it goes
Peripherials included onboard:
Momentary switch buttons and 12 keys numeric keyboard;
16x2 chars LCD Display;
Leds BUS and 7 segments HEX Displays;
USART (Serial Port);
USB (Universal Serial Bus);
Ethernet port accessed by I²C ®
BUS I²C ® , SPI® and CAN BUS;
Radio Transceiver for 433.92MHz;
Crystal Oscillator or external fixed/variable clock;
Temperature Sensor accessed by 1-wire® technology;
Triac for AC/DC power circuit switching;
EEPROM Memory accessed by I²C ® technology;
Real Time Clock accessed by I²C ® technology;
Analogue Inputs to use with PIC's ADC's;
Total access from outside to the micro-controller ports;
External pulse input;
ICD (In Circuit Debugger) - Step-by-step debugging;
Proto-board for auxiliary circuit testing;
* Compatible with RS232/USB Bootloader. *
* Compatible with BasicStamp *
regards
asena
pic16f board
dear mbyka
if you have PCB for this Development Board please send it
S 8O KRAT
    SphinX
pic 16f877 development kit
I have
enjoy to develop :D
pic development board schematic
Hi nooknikz,
The rar file seems to have some problems. Is it the cadstar PCB file.
TIA
BRM
pic16f877 development boards
unzip cp877v12.rar by winrar v3.0 up
and open cp877v12.pcb by protel (pcb) v2.5 or protel 99 se
pic16f877a pcb
and open cp877v12.pcb by P*otel (pcb) v2.5 or P*otel 99 se
DEAR nooknikz very thanks but i dont have protel :cry:
you can convert it to PDF please :?:
thanks
S 8O KRAT
pic16f877 project board with pcb layout
hello,
This is the pdf version of the board.
I'm not sure it is simple to realize it.
CD:)
pic16f877a pcb board
Dear nooknikz
it is not mbyka Development Board :!:
please send Schematic as PDF
THANKS
S 8O KRAT
pic16f877 pcb
Hi Sokrat,
Why do you want the schematic?
The component values are shown in the placement diagram.
Bye
    V
pic16f877 dev kit free
SphinX said:
Hi Sokrat,
Bye
Don't start any project before you sure all resource with you :wink:
S 8O KRAT
pic16f877a circuit
Hi, John Peatman got a great book on PIC18F455, this book comes with a free PCB for PIC18F455. You can save great value using this PCB to build a PIC18F455 board, intsead PIC16F877. Both ICs are pin compatible; just that PIC18 has more flash memory. It comes with a RJ Socket for ICD debugger + programming.
http://www.picbook.com/qwikflash.html
pic16f877a pcb layout
DEAR lguancho
do have this book as PDF
S 8O KRAT
pic16f877a development board schematic
Nope, I don't have the ebook for it. I bought the hardcopy because I want to use the PCB.
By the way, to fabricate this PCB (FR4 2 layer board) is also half the cost of the book. If you buy the book, it comes free. Really worth it.
I tried to scan some books before, believe me, the quality is really bad. You need to do some image processing.
pic16f877a circuit board
hi mbyka
Do u have pic easy in the protel format instead of pdf and also pcb layout for it to
thanks
snaper
