You have given the MUSIC algorithm code with circular array geometry. Its very good and works correctly. But if instead of circular array, we have L-type array geometry, then how will we change your code? Further, if we change the position of L-type array i.e., initially its on xy-axes, then lets say we move it to yz-axes or zx-axes, then how will we change the code?
Further, if a ULA is along x-axis, then it will estimate elevation angle, but if we place the same ULA on y-axis, then will it estimate elevation angle or azimuth angle?
Regards,
