[SOLVED] How to edit the manually made symbol in the cadence?
parminder
Member level 3
Hi, i have created symbol from schematic in cadence but forget to add one pin. how can i edit it ? Or i have to delete existing symbol and create again
Thanks
I would recommend you regenerate from schematic, because there's a lot
of tag-along properties & CDF stuff that are invisible while editing the
symbol view.
If you have made a pretty version, save the graphics to another cellview
and copy that back, keeping the new pins and "background".
There's probably a way to modify but I've found just redoing the from-
schematic generation, more efficient and "oops!"-free.
