sit_ec_2024
Newbie
We have designed both a single-stage power amplifier and a power amplifier using a power combiner, but we are not achieving suitable results. Please find the screenshots below for the circuit designs.
You can connect input and output matching circuit and find output power.-Where are Output and Input Matching Circuits ?
By doing load pull analysis, you can find optimum load analysis later same is set at the load PA amplifier circuit.-How did you define Optimum Load Impedance and for which purpose ?
You can connect 180 degree 3- dB hybrid coupler and try to combine output power as I have attached screen shot below for your reference.-How do you desire to get an meaningful Output Power by driving the amplifiers with 0° Power splitter ?
-How could you define the Operating Point by using which criteria you've used ?
You can perform DC load line analysis to get the operating point Vds = 28 V and Ids = 20 mA.
For your single stange amplifier, you also got no power gain.We have also designed a power amplifier by using power splitter and combiner at input but we are getting a output power less than input power.
No, you didn't design an "Amplifier", you designed an "Attenuator". It amplifies nothing but it attenuates. Don't you se that ?We have designed a single stage power amplifier and we have got 32.492 dBm for input power of 33dBm. We have also designed a power amplifier by using power splitter and combiner at input but we are getting a output power less than input power. Please find the screenshots below for the circuit designs.
You will not answer to me, you will quote of topic owner.You can connect input and output matching circuit and find output power.
