cupoftea
Advanced Member level 5
Why do we not get Controller chips for 50Hz Mains inverters?
I mean, surely if we can have controller chips for PFC, then we can have them for inverters?
Isn’t all that is needed is to sense the rectified and divided down Vout, and then compare it to a sinusoidal reference, via an error amplifier, and then control it like that, so that it gives a sinusoidal output voltage regardless of loading? (when i say rectified, i mean only the bit fed to the controller is rectified (for obvious reasons) , as you know, the output is AC voltage)
