Cadence virtuoso bindkey for specific instance
goatmxj666
Hello
I want to load the specitic instance with bindkey in schematic.
I expect that when I press the '1', then 'inv' instance is loaded.
How can I customize the bindkey?
Assuming you mean 'placing an inverter component' when you say ".... then 'inv' instance is loaded." you can set the following into your .cdsinit or into a global bindkeys.
hiSetBindKey("Schematics" "Alt<Key>l" "schHiCreateInst(\"analogLib\" \"ind\" \"symbol\")")
Now of course you need to replace 'analogLib' and 'ind' with your corresponding library and cell.
LaTeX Commands Quick-Menu:
