[SOLVED] ADS simulation : Efficiency optimization
jihen
Junior Member level 3
Algeria
hello. i wanna to optimize efficiency of a rectifier and want i insert the expression of efficiency in "Goal'' , i have this error
Error detected by hpeesofsim during Nominal Optimization `Optim1'. Optimization/Statistics Error: Please check for valid `Expr' field in OptimGoal/YieldSpec item Check the following device: OptimGoal3
any one can help me how to solve this problem or how can i insert an expression in a Goal!!!!!
If the goal is complicated, you can use the MeasEqn element to define the equation, and then use that as a goal.
MeasEqn is found in palette Simulation-S_param
Reactions: jihen
    jihen
Show me netlist.
do you mean that ?
Code dot - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
Options ResourceUsage=yes UseNutmegFormat=no EnableOptim=no TopDesignName="Etude_Redresseur_avec_HSMS2820_lib:Redresseur_Doubleur_Tension_HSMS2820_the_optimisation:schematic"
define DA_LCBandpassDT1_Redresseur_Doubleur_Tension_HSMS2820 ( N__3  N__2 )
parameters  Fs1=.5 GHz  Fp1=1 GHz  Fp2=2 GHz  Fs2=2.5 GHz  Ap=3 dB  As=20 dB  N=0  ResponseType=1  MinLorC=4  Rg=50 Ohm  Rl=50 Ohm  MaxRealizations=25
C:C3  N__2 0 C=3.18058 pF
L:L2  N__3 N__4 L=15.902902 nH R=1e-12 Ohm Noise=yes
L:L3  N__2 0 L=1.327341 nH R=1e-12 Ohm Noise=yes
C:C1  N__3 0 C=3.18058 pF
C:C2  N__4 N__2 C=265.468272 fF
L:L1  N__3 0 L=1.327341 nH R=1e-12 Ohm Noise=yes
end DA_LCBandpassDT1_Redresseur_Doubleur_Tension_HSMS2820
R:R1  Vout 0 R=RL Ohm Noise=yes
S_Param:SP1 CalcS=yes CalcY=no CalcZ=no GroupDelayAperture=1e-4 FreqConversion=no FreqConversionPort=1 StatusLevel=2 CalcNoise=no SortNoise=0 BandwidthForNoise=1.0 Hz DevOpPtLevel=0 \
SweepVar="freq" SweepPlan="SP1_stim" OutputPlan="SP1_Output"
SweepPlan: SP1_stim Start=0 GHz Stop=8 GHz Step=0.01 GHz
OutputPlan:SP1_Output \
      Type="Output" \
      UseEquationNestLevel=yes \
      EquationNestLevel=2 \
      UseSavedEquationNestLevel=yes \
      SavedEquationNestLevel=2
Pin=30
RL=160 opt{ 80 to 240 }
Cf=68 opt{ 34 to 102 }
Freq=2.45
HB:HB1 MaxOrder=4 Freq[1]=Freq GHz Order[1]=3 StatusLevel=2 Restart=no OutputBudgetIV=no SweepVar="Pin" SweepPlan="HB1_stim" OutputPlan="HB1_Output"
SweepPlan: HB1_stim Start=0 Stop=50 Step=0.1
OutputPlan:HB1_Output \
      Type="Output" \
      UseNodeNestLevel=yes \
      NodeNestLevel=2 \
      SavedEquationNestLevel=2 \
      UseDeviceCurrentNestLevel=yes \
      DeviceCurrentNestLevel=0 \
      DeviceCurrentDeviceType="All" \
      DeviceCurrentSymSyntax=yes \
      UseCurrentNestLevel=yes \
      CurrentNestLevel=999 \
      UseDeviceVoltageNestLevel=no \
      DeviceVoltageNestLevel=0 \
      DeviceVoltageDeviceType="All"
Tran:HB1_tran HB_Sol=1 SteadyState=1 StatusLevel=3 \
Freq[1]=Freq GHz Order[1]=3 \
Component:tahb_HB1 Module="ATAHB" Type="ModelExtractor" \
 Tran_Analysis="HB1_tran" HB_Analysis="HB1"
Port:PORT1  Vin 0 Num=1 Z=50 Ohm P[1]=polar(dbmtow(Pin),0) Freq[1]=Freq GHz    Noise=yes Pac=polar(dbmtow(0),0)
#uselib "ckt" , "P_Probe"
P_Probe:P_Probe1  Vin N__17
C:C1  N__6 0 C=Cf pF
L:L1  N__11 N__6 L=100 nH Noise=yes
Short:DC_Block1  N__2 N__14 Mode=1
DA_LCBandpassDT1_Redresseur_Doubleur_Tension_HSMS2820:DA_LCBandpassDT1  N__17 N__2 Fs1=1 GHz Fp1=2 GHz Fp2=3 GHz Fs2=4 GHz Ap=3 dB As=20 dB N=3 ResponseType=1 MinLorC=4 Rg=50 Ohm Rl=50 Ohm MaxRealizations=25
P_Probe:P_Probe2  N__6 Vout
#uselib "HfDiodeLibrary" , "di_hp_HSMS2820_20000301"
di_hp_HSMS2820_20000301:D2  0 N__16 N__14
di_hp_HSMS2820_20000301:D3  N__14 N__9 N__11
OptimGoal:OptimGoal1 Expr="Rendement" SimInstanceName="HB1" Weight=1.0 \
IndepVar[1]="Pin" \
SpecLimitLine[1]="OptimGoal1_limit1" SpecLimitLine[2]="OptimGoal1_limit2"
SpecLimitLine:"OptimGoal1_limit1" Type="GreaterThan" Min=50 Weight=1.0 \
IndepVar[1]="Pin" IndepMin[1]=0 IndepMax[1]=50
SpecLimitLine:"OptimGoal1_limit2" Type="LessThan" Max=100 Weight=1.0 \
Optim:Optim1  OptimType="hpVMO" ErrorForm="L2" MaxIters=50 P=2 DesiredError=0.0 StatusLevel=4 FinalAnalysis="None" NormalizeGoals=yes SetBestValues=yes SaveSolns=yes SaveGoals=yes SaveOptimVars=no UpdateDataset=yes SaveNominal=no SaveAllIterations=no UseAllOptVars=yes UseAllGoals=yes SaveCurrentEF=no InitialTemp=0.1 NumShootsPerIter=20 EnableCockpit=yes SaveAllTrials=no
aele Rendement=(P_Probe2.p[0]/P_Probe1.p[1])*100;
You need to be careful with equation syntax. For example your **2 is not valid, the function is sqr()
Valid equation syntax is given in the ADS help
Reactions: jihen
    jihen
Sorry, no, I don't know what other MeasEqn you have. But you can go step by step and test your equations in Data Display.
sir, i have only this MeasEqn :
can you show me where is the error in these expressions please?
Why don't you check step by step in data display?
In your equation you use RL, but where is RL defined?
