10MEG resistor to set switching frequency of Buck?
cupoftea
We are doing a 214kHz Buck with 24vin and 15vout at 3a(out).(as attached in LTspice)
Using the LTC3878.
-Though it needs a 10 Meg resistor into its RON pin in order to give the 214kHz.
That means a current of just 2.3uA into the RON pin of the LTC3878.
Surely using a 10 MEG resistor to set the switching frequency is asking for trouble? (with noise)
LTC3878 datasheet
  • LTC3878 BUCK.zip
I don´t see a problem in detecting 2.3uA. To keep noise low, just make the node as small as possible.
--> place R9 close to the IC pin.
In the datasheet there is a chart "On-Time vs I_ON Current" ... which shows I_ON go down to 1uA
I see you haven't mastered how to simulate parasitics.
My advice was a result of verifying my advice in LTspice. The consequences increase 50 mVpp output ripple on Vout-15 or worse , overshoot, freq. and damping factors by changing loop gains from +ve or -ve x pF feedback to Ion from each nearby signal.
If you can imagine it, you can simulate it.
Tony
LaTeX Commands Quick-Menu:
