👉 35V-5A Adjustable Switching Power Supply
Hesambook
Full Member level 2
Full Member level 2
In this article/video, I introduce an adjustable 5A DC-to-DC converter circuit that uses an advanced chip, made by Texas Instruments, which is TPS5450. It’s a high-frequency and efficient buck converter chip that provides tight voltage regulation. I have followed several PCB design rules to ensure low noise, low EMI, and high stability of the output voltage.
Please watch the video completely, from the start to the end. I've disclosed the design, provided an article, and shared several PCB designing tricks with you😉
I designed this board using Altium Designer. The PCB has been Fabricated by PCBWay. if you have Altium, I can share the original PCB project with you using Altium 365.😊
References
Full Article, Downloading PCB, Direct Order: http://bit.ly/3SDAyAt
[1]: TPS5450: https://octopart.com/tps5450ddar-texas+instruments-7105511?r=sp
[2]: SS56: https://octopart.com/ss56bf-hf-comchip-107339894?r=sp
[3]: 3590-S2: https://octopart.com/3590s-2-502l-bourns-112621?r=sp
