Great help you guys! Thanks a lot!Something I like to do when trying to find compatible replacement parts fast is to hop on digikey, navigate to the part's category, and use their search filters. I found VP2206N3-G-P003 to be the closest match available by selecting "in-stock", making the minimum Vds the maximum on the original part's datasheet, and picking the device package which is also on the datasheet. Then compared ones from the list that had a max current >= the original's. You might be able to find something even closer if you're willing to use a different devise package, this just happens to be the best digikey can do for something with that exact footprint.
