FreshmanNewbie
Advanced Member level 1
![Advanced Member level 1](/styles/images/ranks/glevel1.gif)
I just want to confirm whether the part zl30251 has phase aligned outputs? If not, can it be aligned?
Also, can you confirm whether both the clock outputs are LVCMOS?
Can you please help me with this?
I want one clock output to be 12.8MHz and the other clock output to be two the frequency of the first clock, i.e, 25.6MHz.
The datasheet mentions that the clock output can be phase aligned. But if the clock outputs are two different frequencies, how can the clock outputs be phase aligned?
Can you help me?
Can you help me?
