Zero voltage output from proteus simulation
TheEngineer
Newbie
Newbie level 1
i am doing a multimode four switch buck-boost converter project and on running the converter simulations on proteus, there is zero output voltage with 256v input. any idea what i might be doing wrong
You should at least show a screenshot or .pdf print of the simulation circuit.
Many possible reasons e.g. using a switch mode controller component without associated simulation model.
LaTeX Commands Quick-Menu:
