danny davis
Banned
How do you tell the difference between a ZERO potential and a ground that is zero volts?
They both are Zero Volts
My Manager gave me an example , when you hook up two different power supplies and set them to the same voltage and measure with your DVM. The potential difference between them is ZERO
So is this an open or short?
If you're bench checking a circuit board and you get NO output from that stage that has a failure, is it a short, open or a Zero potential?
1.) Short has a voltage Potential?
2.) Open has a voltage Potential?
3.) Zero Potential
At work I have a BAD board that has NO output, the output Components are Referenced going to a DC ground, all the other components went to a Signal Ground. I had to Remove each component one by one that was tied going to the DC ground to chase this short. After Removing IC after IC after lifted up components to isolate them for different stages and branches , etc. etc. it still has no output.
Is this the best way to track down a Ground Short? is to remove one component at a time?
My Manager said since there is No output that doesn't mean there is a short because there is Zero volts on the output. It could be it's at a zero potential. What does he mean by this?
I think it has something to do when you have isolated grounds, Digital grounds and Signal Grounds that when you measure between them using a Volt meter it will measure zero potential since they are the same voltage which is ZERO since its ground. The continuity tester on my DVM will measure an OPEN tho between the two isolated grounds
Now if the Digital ground and the Signal Ground are SHORTED , what happens? the Potential is at ZERO volts but you have a SHORT. So the continuity tester on my DVM will measure a SHORT between the two isolated grounds
3.) Zero Potential
