asdf44
- Joined
- Feb 15, 2014
- Messages
- 1,000
- Helped
- 355
- Reputation
- 710
- Reaction score
- 344
- Trophy points
- 1,363
- Activity points
- 9,716
I assume you are wrong here. All energy you need to switch ON a FET (gate charge including miller effect) has to be supplied.Switching speed and gate drive should be irrelevant - the losses from charging and discharging Cosser X times a second are the same regardless of how fast it happens.
I wonder what the term "ZVS" actually addresses in your post. An unloaded H-bridge is hard switching and involves respective switching losses, primarily caused by charging transistor output capacitances and to a lesser extent parasitic board capacitances.
If your circuit actually achieves zero voltage soft switching under normal load conditions, the switching losses can be reduced to a small fraction. Does it?
The "energy related" output capacitance doesn't cover the total switching losses in a hard switching push-pull circuit by the way. Due to the non-linear capacitance characteristic, most losses are caused by charging the off-state transistor.
We don't see a schematic, so all we can do is guessing.
But at switching OFF it is not stored back to thepower supply capacitor, instead it is dissipated to heat.
And often directely (via resistor) supplied by the 400V input voltage. This means every mA of gate drive current causes 1mA x 400V = 400mW of dissipated power.
Klaus
The schematic seems to be sketched a bit sloppily, as it doesn't differentiate between transformer main and leakage inductance. With sufficient low main inductance (air gap required), the circuit can well work as ZVS + ZCS converter.Referencing the schematic I linked above this topology can ZVS when there is sufficient energy stored in L1 to commutate the loop and appropriate dead-time to allow that to happen.
As already stated, Co(er) is underestimating hard switching losses in push-pull operation. If I remember right, the on+off loss total is relative to 2*Co(tr) (Co(tr) = "time related" or average output capacitance).GAN fets have lower losses than my silicon fets despite the fact that they have higher Co(er) at the specified input voltage?
Main inductance will be usually ten times larger than transformer inductance + L1, in so far main inductance rather than L1 is the dominant commutation means.
Read a bit about LLC converters to see that it's a commonly used method.I believe it's not common to rely on magnetizing current to commutate the loop in this topology because any magnetizing inductance that supplies enough current to commutate at light loads amounts to a wasteful amount of extra circulating current at every other operating point.
Esw,tot = Esw1 + Esw2
= ∫Coss(V) V dV + ∫Coss(V)(Vdc - V) dV
= ∫Coss(V) Vdc dV
= avg(Coss(V) Vdc²
= 0.5 Co(er) Vdc² +
(Co(tr) - 0.5 Co(er)) Vdc²
= Co(tr) Vdc²
Klause for the purposes of this discussion any 'phase shift zvs' schematic should suffice:
I agree. Most of this energy is dissipated by the driving circuit, and not inside the MOSFET.I fully understand that driving the gate consumes energy but the component that's 'burnt up' within the fet should be small,
I presume, switching losses of the unloaded H-bridge are determined my measuring the average DC input current. As long as Vdc ripple is low, the capacitor type doesn't matter much in this test setup.Where exactly in this circuit do you measure the current?
What exactly is the capacitor type?
I agree.
I try to call everything into question:
These are just ideas, and maybe the OP can all these issues exclude within seconds.
* Can we be sure that the voltage ripple is low?
What if the capacitor is a ceramics capacitor.. and there is some kind of resonance causing voltage ringing.. in this causing mechanical power dissipation.
* Maybe it is a non suitable electrolytics capacitor.. combined with some ripple voltage/current?
* Is he really measuring averaged DC current? Maybe he is measuring RMS current including the ripple current, so he sees a (parto of) current that doesn´t cause power dissipation.
(An idea because he calculates 1..3W, but this should cause temperature rise. Recognizeable with the touch of a finger)
Klaus
When I'm talking about 'high losses' I'm talking about fets that are burning up - shooting towards 100C before I slam the power button or sitting at 95C with only 200Vin (these tiny packages don't have much thermal margin for error). So I haven't always been recording watts rigorously in instances when the device is clearly not going to cut it though I do believe that input current (losses) and temperature are correlating well.
