raymundor
Newbie level 5
I am building a BLDC controller, the sensorless portion of it is giving me fits. I think its something simple but with several versions of it the comparator or op-amp doesn't give me an output. My test circuit gives a good 1V pk-pk AC wave biased to 1.6V at its 0. but when the inverted input crosses the noninverted input the output doesn't respond. am I missing something? the datasheet for the LM339N that I have on the test bench says the the supply voltage can be 2V - 36V, I am powering with 3.3V supplied from a pi pico. and verified that the signal and supply voltages are reaching the chip. I rarely work with comparators but this is how I understand that they work. I tried using a LM324N (without the bias resistor on the output) and still no joy. however I used a LM358 and it worked, but it is a duel package. thanks for your help. the oscope pic is from pins 5 and 4 of the comparator input.
