zero cross detector that produce 0V to 5V output
newton brawn
Newbie level 6
Newbie level 6
voltage detector
Hi everyone !
Im looking for a zero voltage detector, a circuit that make a pulse every time that the line voltage (230V, 60Hz) cross the zero voltage.
It will be used to fire a thiristor or a IGBT.
Any suggestion ??
Regards
zero volt detector
u have ready made packages that do what you want..........
else you do with opto coupler and PIC say,
Re: Zero voltage detector
Do you mind to send the circuit diagram, and give more eetails ?
Thanks
Newton
Added after 1 minutes:
cameo_2007 said:
sorry, please explain
Thanks
Newton
You can use comparator with zero referance on non inv pin & feed your rectified AC on the inv pin(With proper attenuation) to get ZC pulses on the output.
To be a zero reference comparator the input will have to have pmos devices, correct?
What is ZC pulses?
Hi
See microchip site for X10 application note - you will find there A zero crossing detector as a part of X10 application
All the best
Bobi
The microcontroller specialist
I love this circuit:
//a
