risingcurrent
Newbie level 5
Hi guys
am new to the forum , need a little help with a zener regulator design , am tryign to build a zener regulator which when powered from the ac lines 115 V and 60 hz ,will provide upto 5 volts and 120 milliamperes , the diagram attached below does give 5 volts but give a current which is very less about 20 milliamperes , i dont want to use a transformer in the design , can a darlington pair be used to pump the output current , or is there any other way to modify this design .
all suggestions welcomed .
thank you
thank you
