chyrie
Newbie level 2
Hello,
I am currently working on the Ultrascale+ RFSoC board (ZCU111). I have a clock synchronization problem. I can neither synchronize the card and the spectrum analyzer with the 10 MHz reference signal from the spectrum analyzer, nor retrieve a reference signal from the card and put it at the input of the spectrum analyzer.
I am trying to do a project containing signal processing and we need about 142 Hz of frequency accuracy. Hence the need for synchronization.
It would appear that the reference signal on the card is at more than 3 GHz instead of 10-20 MHz (on J7 and J10).
Here is a DAC measurement on the spectrum analyzer with a 100 Hz span.
Thank you in advance if anyone have an idea or advice.
