your suggestion for a master degree
medra
Full Member level 2
Full Member level 2
Egypt
hot master degrees
Hi all
I hope to hear from you your suggestions about a Master degree topics in digital communication. what is hot now?
Do you encourage working on LDPC and turbo codes?what is hot in coding now?
hope to hear from all of you sson
communication master degree topics
I think coding is overflooded
u can go for Turbo coding
But i suggest to go for Hybrid ARQ/FEC and make it channel Adaptive...........
    medra
suggestion for degree
consider your circumstance of project
LDPC and turbo code is hard, maybe
    medra
why do you consider working on LDPC or turbo codes hard??
please illustarte more
Reed_Solomon using Guruswami-Sudan algorithm (algebraic soft decoding approach) for VLSI
    medra
I would consider neither hard. Thanks to Almighty, I have decent Matlab skills and also comm. algo skills to attempt any of these.
I suggest that, if you have about 4 months, then choose any topic, take 2 weeks to learn how to create a simple modem in Matlab.
After that, learn the theory of your Error Correcting Code and once you are aware of theory, you would naturally know how to write a Matlab code for it (Matlab has a built in function for LDPC)
Use the function in your modem code to get the output.
So if you have good skills in logic, no topic is difficult
If you need some help, you can send an email to yahoo group "telecom_research" and if you are interested in ofdm you can send an email to yahoo group "ofdmandmatlab". Some one might help you there too
    medra
thanks dear Communications_Engineer, do you have another suggestions for a master topic??
Yes , you could considered that I have about 4 monthes , is there some thing specific in LDPC or turbo coding that researcher are working on??
waiting for your appreciated reply
you should familiar with coding theory if you want to study LDPC and turbo coding
    medra
