msmax
Full Member level 1
- Joined
- May 6, 2001
- Messages
- 99
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Location
- Pays Bas
- Activity points
- 919
Have you had good or bad experiences with SPI(CLK,Data,Enable) bus for increasing port outputs.
What set up did you have for your experience:
- bus on same board as micro?
- bus fed by 3 wire cable to seperate board from micro?
I'm using a 3 wire bus with latches to create 56 outputs on a seperate print with a cable of ~1.2 meters.
Problem is that sometimes outputs are are spontanously flashing which should not happen.
Please share your experience with me.
