Fragrance
- Joined
- Jul 26, 2002
- Messages
- 1,190
- Helped
- 248
- Reputation
- 496
- Reaction score
- 202
- Trophy points
- 1,343
- Location
- East Of Earth
- Activity points
- 8,933
I am using proteus pro SP5 successfully with Pic Basic Pro because proteus pro is more flexible then the lite version and can simulate the hex file directly with chip with out building the source code such as .Asm file in side the environment.
This is very simple just select the properties of the chip (Pic chip which you are using in your design) and click the program file option add your hex file with it! Be sure the hex file should be in your proteus directory or folder.
For example compile the basic code using pic basic pro and resulted hex file copy in the proteus folder or directory.
I am going to attach a complete example using proteus with pic basic pro this is flashing led example and also a demo how to add your hex file with chip, see how it work out side the environment,
I hope this will be a good guide to start proteus SP5 with other compiler how ever SP6 have this option built in for c and basic.
To view the demo you must install the java plug in with you Internet explorer once you extract the demo run the file proteus_viewlet.html
REGARDS
KHALID :lol:
REGARDS
KHALID :lol:
