XR-8038A function generator IC datasheet question.
boylesg
Epping, Victoria, Australia
What is Vsup? There is no explanation of it any where in the datasheet.
If Vcc is +9V and Vee is -9V then what voltages should Vin be between?
Is Vsup = Vcc - Vee?
In my case that would be about 16.8V since I am using 2 x 9V NiMH batteries in series with GND in the middle. Which output about 8.4V or so.
--- Updated ---
And another question re this....
Would 100nF and 10k be OK for that cap and resistor on pins 7 and 8?
Yes Vsup = Vcc - Vee
The R on FMB1 allowed to go to 1 Mohm. C, not sure, as there is no
data on Zin of the FMS1 pin, but try your val out,m should be fine I
think.
Regards, Dana.
I´d say the C (in combination with the R) determines the lower cutoff frequency for the modulation.
Or the other way round: calculate C by using R and fc
Klaus
I would say its more compicated than just simple RC calculation of
externals based on whats connected to pins 7 and 8 :
However looks like we can "swamp" out the effective internal Z's with large R. assuming
Rextb is small relative to the R on pin 8.
Regards, Dana.
Klaus
So I take it that capacitor and resistor forms a low pass filter then? Which I would have to refresh my memory on.
Exernal R has to be added to internal R of pin 7 (8k) to get the total R for fc calculation.
(ignoring Pin8 current)
Klaus
A LPF would help remove noise and unwanted changes to your control V input
signal. So it would aid in making your modulation input, your control signal, free
of any unwanted deviations from what you would like.
Regards, Dana.
I agree that a low pass filter attenuates noise (and jitter)
But the R-C at the FM input of post#1 form a HIGH pass filter.
Klaus
Practically speaking are we DC coupled when we use a bulk cap, like electrolytic, or
any cap for that matter, with their leakage issues ? Eg. we cant actually build a true
HPF....Just asking for a friend. :)
Regards, Dana.
Yes, if you are focussed on the leakage current of a capacitor ... rather than it´s function as a capacitor.
Klaus
Of course we care about non perfect components, like caps. Their ESR,
for some (ceramics) wild dependency on V, or T dependence, mechanical
microphonics.....to name a few. Should we be worried about muon and
neutrino interaction in dielectrics ? Gravitational waves, all should be
focused on.
Buts its fascinating, is there such a thing as a realizable HPF ? I am having
my doubts.
Regards, Dana.
I guess you´re getting off topic.
You are free to start your new thread for discussions of non perfect parts and whether a HPF realizable.
Please here post topic related content only.
Klaus
