Xpath error: unbalanced parantheses found in Expression
Sunayana Chakradhar
Member level 5
Member level 5
I am packaging my custom logic with axi lite and in customization window I get xpath unbalanced parantheses error. I have used generic in my code and in top module I have used generic map also. Still this error. What should I do to resolve this?
The problem is probably in line 15 of your code.
how are you so sure that the problem is in line 15 of my code? i have not even uploaded my code.
My code goes like this
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use ieee.numeric_std.all;
use ieee.std_logic_misc.all;
use ieee.std_logic_unsigned.all;
library axi_lite_ipif_v3_0_4;
use axi_lite_ipif_v3_0_4.ipif_pkg.all;
use ieee.std_logic_arith.all;
entity decode_top_new is
generic (
        c_s_axi_data_width    : integer := 32;
        c_s_axi_addr_width    : integer                   := 32;
        c_s_axi_min_size      : std_logic_vector(31 downto 0):= X"000002FF";
        c_use_wstrb           : integer := 0;
        c_dphase_timeout      : integer range 0 to 512 := 8;
     c_ard_addr_range_array: slv64_array_type :=
              x"0000000070000000", -- IP user0 base address
             x"00000000700000FF", -- IP user0 high address
             x"0000000070000100", -- IP user1 base address
             x"00000000700001FF"
               c_ard_num_ce_array     : integer_array_type :=
                  4,         -- User0 CE Number
                  12         -- User1 CE Number
               c_family              : string  := "zynq"
    port(
I think he was providing as good an answer as you provided a question. My answer would have been : Re-balance the Paranthesis.
You havent posted all of the code, or the error, so still cannot really help you.
