raman00084
Full Member level 6
![Full Member level 6](/styles/images/ranks/flevel3.gif)
i bought a xmos start kit from element 14 in this board there is one 5v pin and 6 ground pins all the ground pins are inter connected internally, if i connect a +5v and ground to any one of the ground pins my board works.
my doubt is why 6 ground given ?
one of my friend said you must connect at-least 3 to 4 grounds from the power supply to eliminate spike in ground i cant understand what is this since all the 6 grounds are inter connected internally why i must connect the same ground to 3 or 4 pins what is the use how it will avoid ground voltage fluctuation.
kindly help
regards
kalyan
kindly help
regards
kalyan
