Lokesh Waran
Junior Member level 1
Dear all,
Presently we are doing some automation operation using micro controllers but i wish to change the technology to CPLD/FPGA .So, i wrote some verilog program in XILINX (XC9572XL) but it has 2 micro-cells of memory so i could not able implement the all coding in to that device . So, i tried to go for FPGA spartan 3AN (XC3S50AN) device. But I have confused with logic cells in spartan 3an and macrocells in CPLD memory like how much line of coding can able to write in spartan 3an device the sparatan XC3S50AN has 1584 logic cells specified in a data sheet. But I need the following memory specifications for my process.
TECHNICAL SPECIFICATIONS TO BE NEED
4K Flash Memory
16K RAM
UART-1number
Timer 16Bit- 2numbers
External Interrupts-3Numbers
Internal Core Frequency -100 Mhz
Minimum I/O - 60 above Pins
Package type -TQFP/QFN
Xilinx JTAG Platform cable (DS-10) Compatibility
thanks for all ..............
4K Flash Memory
16K RAM
UART-1number
