Xilinx simulator problem
madhav766
Newbie level 1
Newbie level 1
i just started using Xilinx ISE 9.1i. I need the ISE simulator to be working. But doesnt seem to be there. Is there a way I can add the simulator?? While installing, a zip file called "drop28.zip" showed up as an error. Also in the sources window, i don seem to be able to go into anything else other than synthesis!:shock: no implementation option!!!
