Xilinx-modelsim integration problem
diju.ms
Newbie level 5
Newbie level 5
haai
i am using xilinx 9.2 for VHDL/Verilog coding.My simulation tool is Modelsim 10.0.I have set the integrated tools option in xilinx as modelsim.For VHDL it is working perfectly.but when i am simulating Verilog model sim shows the error every time.I am not able to understand what it is...can anyone please help me...
the error message is.......
do {mux.fdo}
# ** Warning: (vlib-34) Library already exists at "work".
# Model Technology ModelSim SE vlog 10.0b Compiler 2011.05 May 5 2011
# -- Compiling module mux
# Top level modules:
# mux
# -- Compiling module glbl
# glbl
# vsim -L cpld_ver -L uni9000_ver -lib work -t 1ps mux glbl
# ** Note: (vsim-3812) Design is being optimized...
# ** Error: (vopt-19) Failed to access library 'cpld_ver' at "cpld_ver".
# No such file or directory. (errno = ENOENT)
# ** Error: (vopt-19) Failed to access library 'uni9000_ver' at "uni9000_ver".
# ** Error: C:/Xilinx92i/verilog/src/glbl.v(58): Vopt Compiler exiting
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./mux.fdo PAUSED at line 7
There are problems related to the accessing libraries use in glbl.v code. You have to check where is the libraries (cpld_ver and uni9000_ver) directories and make sure it is compiled before compiling the glbl.v code.
Thanks.
i am not able to solve this problem..i tried all options in the simulator options.one of my friend is using the same softwares and same versions...he is not having this problem...can anyone please help me???
From the error, it is clear that the simulator did not find 2 libraries in order to continue the simulation process. There is no problem with the simulator itself (that's why your friend does not have problem at all). It is the problem of setting/configuration in order to tell the simulator to look at certain directories to be able to find the libraries that you use in your HDL.
Is the cpld and uni9000 library is in the same directory you run the simulation or in other directory?
Thanks.
