Xilinx ISE installation problem!
dspti
Newbie level 6
Newbie level 6
xilinx authentication rejected
Hi all,
Firstly, i downloaded the 8_1_03i_lin.zip from www.xilinx.com website
and its size is about 130M.
130224509 03-30 01:04 8_1_03i_lin.zip
then unzip this file to run ./setup
but it appear one dialogue box which needed one installation directory.
it was error when i give any existed directory.
what's matter about this?
The dialogue box show the following text :
"Welcome to the Xilinx Service Pack Installation Program. The path displayed is your current XILINX installation, this service pack will be applied to this location.
Selet the directory where you want the software installed.
______________________ |Browse....|
This Xilinx Software Installation include following two steps:
-> Select Destination Directory
Begin Installation
Thanks a lot.
ise installation
You are trying to install service pack , have to donwload webpack ise (about size of CD)
xilinx 8.1 on fedora installation
Could you give me a link?
In xilinx website, i can only find this file!!!
Thanks
xilinx ise 8.1 webpack
webpack ise 8.1 for linux should be that one :
    dspti
webpack ise 8.1 + www.direct
Thanks very much!
xilinx select installation options
Hi artem,
After download .sh file successfully,
run sh *.sh under this directory, and there's pop-up windows of steps of Installation.
There'are following errors in the terminal, and the install going on.....
after 100% installatoin finished. there's a error message comes out (seen as the attachment)
Could you tell me where's the problem?
Thanks a lot.
Verifying archive integrity... All good.
Uncompressing Xilinx ISE WebPACK Installer.....................................................................................................................................................................................................
Session management error: Authentication Rejected, reason : None of the authentication protocols specified are supported and host-based authentication failed
xilinx ise fedora install
And after that, how to start the ISE ??
i can not find some scripts under /xilinx/bin/lin .
xilinx installation problems
dspti, i did not install webpack on Linux . The only thing i can say - from the system platform requirements it needs "Red Hat Enterprise 3 Linux" . If your linux distribution is different , even version - this could be a problem .
xilinx service pack error
O, it's so pity!
I'm worked on Fedora 5.
Are there any free or for student sythesis tool??
Thanks
xilinx ise installation problem
so what will u do....can u have another version of linux on one pc or will u just get redhat enterprise...
did u face any other problems while installing it....or was it okay..??? cause i need to install xilinx on linux too
thanks,
Salma
