uglyduck
Junior Member level 2
xilinx timespec
Hello, Verilog gurus,
I'm experiencing the following problem:
I try to implement a design on Xilinx CoolRunner II using ISE WebPack 7.1.i_04. The design is written in Verilog. The design uses 1.8432MHz clock which is internally divided when needed to ~20Hz. Behavioral simulation is passed OK. But when I try to run "Implement design" from "Processes for source..." I get the following error (warning actually) messages:
Started process "Generate Timing".
Release 7.1.04i - Timing Report Generator H.42
Copyright (c) 1995-2005 Xilinx, Inc. All rights reserved.
Note: This design contains no timing constraints.
Note: A default set of constraints using a delay of 0.000ns will be used for
analysis.
WARNING:Cpld:310 - Cannot apply TIMESPEC TS1000 =
PERIODERIOD_SPEED/PULSE/q10_MC.Q:0.000 nS because of one of the following:
(a) a signal name was not found; (b) a signal was removed or renamed due to
optimization; (c) there is no path between the FROM node and TO node in the
TIMESPEC.
WARNING:Cpld:310 - Cannot apply TIMESPEC TS1001 =
PERIODERIOD_SPEED/PULSE/q1_MC.Q:0.000 nS because of one of the following:
TIMESPEC.
WARNING:Cpld:310 - Cannot apply TIMESPEC TS1002 =
PERIODERIOD_SPEED/PULSE/q2_MC.Q:0.000 nS because of one of the following:
TIMESPEC.
WARNING:Cpld:310 - Cannot apply TIMESPEC TS1003 =
PERIODERIOD_SPEED/PULSE/q3_MC.Q:0.000 nS because of one of the following:
TIMESPEC.
WARNING:Cpld:310 - Cannot apply TIMESPEC TS1004 =
PERIODERIOD_SPEED/PULSE/q4_MC.Q:0.000 nS because of one of the following:
TIMESPEC.
WARNING:Cpld:310 - Cannot apply TIMESPEC TS1005 =
PERIODERIOD_SPEED/PULSE/q5_MC.Q:0.000 nS because of one of the following:
TIMESPEC.
WARNING:Cpld:310 - Cannot apply TIMESPEC TS1006 =
PERIODERIOD_SPEED/PULSE/q6_MC.Q:0.000 nS because of one of the following:
TIMESPEC.
WARNING:Cpld:310 - Cannot apply TIMESPEC TS1007 =
PERIODERIOD_SPEED/PULSE/q7_MC.Q:0.000 nS because of one of the following:
TIMESPEC.
WARNING:Cpld:310 - Cannot apply TIMESPEC TS1008 =
PERIODERIOD_SPEED/PULSE/q8_MC.Q:0.000 nS because of one of the following:
TIMESPEC.
WARNING:Cpld:310 - Cannot apply TIMESPEC TS1009 =
PERIODERIOD_SPEED/PULSE/q9_MC.Q:0.000 nS because of one of the following:
TIMESPEC.
Path tracing .........
The number of paths traced: 905.
The number of paths traced: 1811.
Checking for asynchronous logic...
Generating TA GUI report ...
Generating detailed paths report ...
c:\xilinx\work\robot/SpeedMesTop_html/tim/timing_report.htm has been created.
I have written a testbench in Verilog. I have assigned all the pins I will use. No other constraints. I suppose I have to make some "Time constraints", but...
Explanations, given by the ISE are not very meaningfull to me. Please, help me. Where I'm wrong? My other smaller designs have been implemented this way - no special constraints - just the pin assignment.
When actually timing constraints are needed?
How to use them (just the basic stuff and the most common)?
And why I cannot perform Post-Fit Simulation using such a simple testbench? I miss something essential and eventually very simple, but don't know what to do.
Please, I desperately need your help.
analysis.
TIMESPEC.
TIMESPEC.
TIMESPEC.
TIMESPEC.
TIMESPEC.
TIMESPEC.
TIMESPEC.
TIMESPEC.
TIMESPEC.
TIMESPEC.
