the design under test was
// Copyright (c) 1999 Thomas Coonan (tcoonan@mindspring.com)
// This source code is free software; you can redistribute it
// and/or modify it in source code form under the terms of the GNU
// General Public License as published by the Free Software
// Foundation; either version 2 of the License, or (at your option)
// any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with this program; if not, write to the Free Software
// Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA
module idec (
inst,
aluasel,
alubsel,
aluop,
wwe,
fwe,
zwe,
cwe,
bdpol,
option,
tris
input [11:0] inst;
output [1:0] aluasel;
output [1:0] alubsel;
output [3:0] aluop;
output wwe;
output fwe;
output zwe;
output cwe;
output bdpol;
output option;
output tris;
reg [14:0] decodes;
// For reference, the ALU Op codes are:
// ADD 0000
// SUB 1000
// AND 0001
// OR 0010
// XOR 0011
// COM 0100
// ROR 0101
// ROL 0110
// SWAP 0111
assign { aluasel, // Select source for ALU A input. 00=W, 01=SBUS, 10=K, 11=BD
alubsel, // Select source for ALU B input. 00=W, 01=SBUS, 10=K, 11="1"
aluop, // ALU Operation (see comments above for these codes)
wwe, // W register Write Enable
fwe, // File Register Write Enable
zwe, // Status register Z bit update
cwe, // Status register Z bit update
bdpol, // Polarity on bit decode vector (0=no inversion, 1=invert)
tris, // Instruction is an TRIS instruction
option // Instruction is an OPTION instruction
} = decodes;
// This is a large combinatorial decoder.
// I use the casex statement.
always @(inst) begin
casex (inst) // synopsys parallel_case
// *** Byte-Oriented File Register Operations
// A A ALU W F Z C B T O
// L L O W W W W D R P
// U U P E E E E P I T
// A B O S
// L
12'b0000_0000_0000: decodes = 15'b00_00_0000_0_0_0_0_0_0_0; // NOP
12'b0000_001X_XXXX: decodes = 15'b00_00_0010_0_1_0_0_0_0_0; // MOVWF
12'b0000_0100_0000: decodes = 15'b00_00_0011_1_0_1_0_0_0_0; // CLRW
12'b0000_011X_XXXX: decodes = 15'b00_00_0011_0_1_1_0_0_0_0; // CLRF
12'b0000_100X_XXXX: decodes = 15'b01_00_1000_1_0_1_1_0_0_0; // SUBWF (d=0)
12'b0000_101X_XXXX: decodes = 15'b01_00_1000_0_1_1_1_0_0_0; // SUBWF (d=1)
12'b0000_110X_XXXX: decodes = 15'b01_11_1000_1_0_1_0_0_0_0; // DECF (d=0)
12'b0000_111X_XXXX: decodes = 15'b01_11_1000_0_1_1_0_0_0_0; // DECF (d=1)
12'b0001_000X_XXXX: decodes = 15'b00_01_0010_1_0_1_0_0_0_0; // IORWF (d=0)
12'b0001_001X_XXXX: decodes = 15'b00_01_0010_0_1_1_0_0_0_0; // IORWF (d=1)
12'b0001_010X_XXXX: decodes = 15'b00_01_0001_1_0_1_0_0_0_0; // ANDWF (d=0)
12'b0001_011X_XXXX: decodes = 15'b00_01_0001_0_1_1_0_0_0_0; // ANDWF (d=1)
12'b0001_100X_XXXX: decodes = 15'b00_01_0011_1_0_1_0_0_0_0; // XORWF (d=0)
12'b0001_101X_XXXX: decodes = 15'b00_01_0011_0_1_1_0_0_0_0; // XORWF (d=1)
12'b0001_110X_XXXX: decodes = 15'b00_01_0000_1_0_1_1_0_0_0; // ADDWF (d=0)
12'b0001_111X_XXXX: decodes = 15'b00_01_0000_0_1_1_1_0_0_0; // ADDWF (d=1)
12'b0010_000X_XXXX: decodes = 15'b01_01_0010_1_0_1_0_0_0_0; // MOVF (d=0)
12'b0010_001X_XXXX: decodes = 15'b01_01_0010_0_1_1_0_0_0_0; // MOVF (d=1)
12'b0010_010X_XXXX: decodes = 15'b01_01_0100_1_0_1_0_0_0_0; // COMF (d=0)
12'b0010_011X_XXXX: decodes = 15'b01_01_0100_0_1_1_0_0_0_0; // COMF (d=1)
12'b0010_100X_XXXX: decodes = 15'b01_11_0000_1_0_1_0_0_0_0; // INCF (d=0)
12'b0010_101X_XXXX: decodes = 15'b01_11_0000_0_1_1_0_0_0_0; // INCF (d=1)
12'b0010_110X_XXXX: decodes = 15'b01_11_1000_1_0_0_0_0_0_0; // DECFSZ(d=0)
12'b0010_111X_XXXX: decodes = 15'b01_11_1000_0_1_0_0_0_0_0; // DECFSZ(d=1)
12'b0011_000X_XXXX: decodes = 15'b01_01_0101_1_0_0_1_0_0_0; // RRF (d=0)
12'b0011_001X_XXXX: decodes = 15'b01_01_0101_0_1_0_1_0_0_0; // RRF (d=1)
12'b0011_010X_XXXX: decodes = 15'b01_01_0110_1_0_0_1_0_0_0; // RLF (d=0)
12'b0011_011X_XXXX: decodes = 15'b01_01_0110_0_1_0_1_0_0_0; // RLF (d=1)
12'b0011_100X_XXXX: decodes = 15'b01_01_0111_1_0_0_0_0_0_0; // SWAPF (d=0)
12'b0011_101X_XXXX: decodes = 15'b01_01_0111_0_1_0_0_0_0_0; // SWAPF (d=1)
12'b0011_110X_XXXX: decodes = 15'b01_11_0000_1_0_0_0_0_0_0; // INCFSZ(d=0)
12'b0011_111X_XXXX: decodes = 15'b01_11_0000_0_1_0_0_0_0_0; // INCFSZ(d=1)
// *** Bit-Oriented File Register Operations
// A B O S
// L
12'b0100_XXXX_XXXX: decodes = 15'b11_01_0001_0_1_0_0_1_0_0; // BCF
12'b0101_XXXX_XXXX: decodes = 15'b11_01_0010_0_1_0_0_0_0_0; // BSF
12'b0110_XXXX_XXXX: decodes = 15'b11_01_0001_0_0_0_0_0_0_0; // BTFSC
12'b0111_XXXX_XXXX: decodes = 15'b11_01_0001_0_0_0_0_0_0_0; // BTFSS
// *** Literal and Control Operations
// A B O S
// L
12'b0000_0000_0010: decodes = 15'b00_00_0010_0_1_0_0_0_0_1; // OPTION
12'b0000_0000_0011: decodes = 15'b00_00_0000_0_0_0_0_0_0_0; // SLEEP
12'b0000_0000_0100: decodes = 15'b00_00_0000_0_0_0_0_0_0_0; // CLRWDT
12'b0000_0000_0101: decodes = 15'b00_00_0000_0_1_0_0_0_1_0; // TRIS 5
12'b0000_0000_0110: decodes = 15'b00_00_0010_0_1_0_0_0_1_0; // TRIS 6
12'b0000_0000_0111: decodes = 15'b00_00_0010_0_1_0_0_0_1_0; // TRIS 7
// A B O S
// L
12'b1000_XXXX_XXXX: decodes = 15'b10_10_0010_1_0_0_0_0_0_0; // RETLW
12'b1001_XXXX_XXXX: decodes = 15'b10_10_0010_0_0_0_0_0_0_0; // CALL
12'b101X_XXXX_XXXX: decodes = 15'b10_10_0010_0_0_0_0_0_0_0; // GOTO
12'b1100_XXXX_XXXX: decodes = 15'b10_10_0010_1_0_0_0_0_0_0; // MOVLW
12'b1101_XXXX_XXXX: decodes = 15'b00_10_0010_1_0_1_0_0_0_0; // IORLW
12'b1110_XXXX_XXXX: decodes = 15'b00_10_0001_1_0_1_0_0_0_0; // ANDLW
12'b1111_XXXX_XXXX: decodes = 15'b00_10_0011_1_0_1_0_0_0_0; // XORLW
default:
endcase
end
endmodule
