WS2812B how is it with timing ?
carpenter
Full Member level 6
Full Member level 6
I am considering using the RGB LED WS2812B as a signal LED with an MCU, 1 up to 5 pcs.
I found several different datasheets unfortunately, the timing of the communication protocol differs quite fundamentally in them.
Does anyone have real experience with these LEDs?
I don't want to bypass PWM or SPI or other HW, but connect to general GPIO
and on STM32F then let's look at T0H max 380ns and min 5 instructions are based on a minimum clock of 14MHz
View attachment WS2812Ba.pdfView attachment WS2812B.pdf
if I understood the datasheet correct, 24 bits are reqired to set the color of the LED. 8 bit for the red value, 8 bit for the blue value and 8 bit for green.
According to the sequence chart on page 4 a time of 800 ns ~ 1.38 µs is required to set a single bit (T0H + T1H or T0L + T1L). The smallest time instance is 220 ns which corresponds to a frequency of ~4.55 MHz. Which should not be a problem with a STM32F if not operated at a low frequency.
As the 5 LEDs are wired in series, they are daisy chained. Consequently it takes more time until the last LED receives the intended color information, as its information is shifted through the registers of the previous LEDs. So you have to send the color information of the 5th LED first followed by the color of the 4th and so on.
So basically the only information you are interested in is the minimum microcontroller wait time of 220 ns ~ 380 ns (as it seems you are aiming to communicate by bit banging). The overall time untill all 5 LEDs are correctly set shoud last (800 ns ~ 1.38 µs) • Numbers of LEDs • Data length = (800 ns ~ 1.38 µs) • 5 • 24 = 96 µs ~ 165.6 µs.
greets
In essence, YES.
the most critical seems to be the shortest time period it is T0H
which is according to one datasheet
220ns - 380ns
according to the second
250ns - 550ns
because my assembler code needs at least 5 clock cycles for this part of the program
380/5= approximately 13,2MHz
550/5= approximately 9,1MHz
and one more approach is possible
in one dataseeet is Th+Tl= 125us +- 600ns e.i. max 1850ns with with a ratio of 1/3 to 2/3
600/5= approximately 8,4MHz
I am struck by the ambiguity with which the manufacturer states the timing of the data protocol.
Ok, if I understand you correct you need least 5 clock cycles to perform a value change at the data pin.
At witch frequency will your MCU be operated? Are you using an external oscillator/crystal, or are you using the internal RC oscillator?
Where do you source your LEDs? Large distributers like digikey, farnell or mouser usually provide the datasheet where you should find valid timings.
Is it not possible to adjust your code afterwards? What are your limitations by means of MCU operation frequency? Or is it a power consumption issue?
greets
hello,
i deeply study this device and did many measurements with a logic analyser
to build the correct protocole in ASM ( mixed into C langage)
i use a PIC18F26K22 at 64MHz .. effective cycle is 4/64 µS => 62.5nS
see HERE
even in French .. but maybe usefull
main datas are
WS2812
[FONT=&quot]Operation frequency Fosc2 —— —— 800 —— KHz[/FONT]
[FONT=&quot]transmission data rate mini 400Kbps[/FONT]
[FONT=&quot]Data transfer time( TH+TL=1.25µs±600ns)[/FONT]
[FONT=&quot]T0H 0 code ,high voltage time 0.35us ±150ns[/FONT]
[FONT=&quot]T1H 1 code ,high voltage time 0.7us ±150ns[/FONT]
[FONT=&quot]T0L 0 code , low voltage time 0.8us ±150ns[/FONT]
[FONT=&quot]T1L 1 code ,low voltage time 0.6us ±150ns[/FONT]
[FONT=&quot]RES low voltage time Above 50µs[/FONT]
