muyalrabbit
Newbie level 5
Hi Fallowing Is My Code To Write Value 2 At Address 0x08 Of
EEProm AT24C512 Using AT89s52.
The Code Executes And No Value Is Written On ROM
Help Me Debug This.
;CODE FOR AT89S52
;EEPROM AT24C512
;WRITING VALUE 2 AT EEPROMS 0X08
ORG 0H
VRBLS: ;VARIABLES
SCL EQU P2.0 ;I2C CLOCK
SDA EQU P2.1 ;I2C DATA
I2CDAT EQU 28H ;I2C DATA VARIABLE
SJMP START ;GOTO START
;I2C MODULE START
I2CSTART: ;I2C START
SETB SDA
SETB SCL
NOP
NOP
CLR SDA
NOP
NOP
CLR SCL
RET
I2CSTOP: ;I2C STOP
CLR SDA
SETB SCL
NOP
NOP
SETB SDA
NOP
NOP
RET
I2CWRBT: ;I2C WRITE A BYTE
CLR SCL ;I2C CLOCK LOW
MOV SDA,47H ;SENDING MSB OF I2CDATA
ACALL I2CCLK ;I2C CLOCK
MOV SDA,46H ;SENDING NEXT BIT OF I2CDATA
ACALL I2CCLK
MOV SDA,45H
ACALL I2CCLK
MOV SDA,44H
ACALL I2CCLK
MOV SDA,43H
ACALL I2CCLK
MOV SDA,42H
ACALL I2CCLK
MOV SDA,41H
ACALL I2CCLK
MOV SDA,40H ;SENDING LSB OF I2CDATA
ACALL I2CCLK ;12C CLOCK
RET
I2CCLK: ;I2C CLOCK
SETB SCL
NOP
NOP
CLR SCL
NOP
NOP
RET
I2CACK: ;I2C ACKNOWLEDGE
CLR SCL
SETB SCL
NOP
JNB SDA,I2CAKD
CLR SCL
RET
I2CAKD:
CLR SCL
RET
;I2C MODULE END
;EEPROM MODULE START
EEWRADD: ;EEPROM ADDRESS WITH WRITE ENABLE
MOV I2CDAT,#0A6H ;SEND DEVICE ADDRESS + ENABLE WRITE
ACALL I2CWRBT
ACALL I2CACK
RET
EERDADD: ;EEPROM ADDRESS WITH READ ENABLE
MOV I2CDAT,#0A7H ;SEND DEVICE ADDRESS + ENABLE WRITE
ACALL I2CWRBT
ACALL I2CACK
RET
;EEPROM MODULE END
START:
ACALL I2CSTART ;I2C START
ACALL EEWRADD ;I2C WRITE DEVICE ADDRESS WITH WRITE OPTION
MOV I2CDAT,#0H ;I2C EEPROM ADDRESS LOCATION (1ST BYTE)
ACALL I2CWRBT ;I2C WRITE
ACALL I2CACK ;I2C ACKNOWLEDGE
MOV I2CDAT,#08H ;12C EEPROM ADDRESS LOCATION (2nd BYTE)
MOV I2CDAT,#02H ;WRITE VALUE 2 TO EEPROM
ACALL I2CACK ;I2C ACKNOWLEGE
ACALL I2CSTOP ;I2C STOP
HERE: SJMP HERE ;STAY HERE
END
Help Me Debug This.
;CODE FOR AT89S52
;EEPROM AT24C512
ORG 0H
VRBLS: ;VARIABLES
;I2C MODULE START
SETB SDA
SETB SCL
NOP
NOP
CLR SDA
NOP
NOP
CLR SCL
RET
I2CSTOP: ;I2C STOP
CLR SDA
SETB SCL
NOP
NOP
SETB SDA
NOP
NOP
RET
ACALL I2CCLK
MOV SDA,45H
ACALL I2CCLK
MOV SDA,44H
ACALL I2CCLK
MOV SDA,43H
ACALL I2CCLK
MOV SDA,42H
ACALL I2CCLK
MOV SDA,41H
ACALL I2CCLK
RET
I2CCLK: ;I2C CLOCK
SETB SCL
NOP
NOP
CLR SCL
NOP
NOP
RET
CLR SCL
SETB SCL
NOP
JNB SDA,I2CAKD
CLR SCL
RET
I2CAKD:
CLR SCL
RET
;I2C MODULE END
ACALL I2CWRBT
ACALL I2CACK
RET
ACALL I2CWRBT
ACALL I2CACK
RET
;EEPROM MODULE END
START:
END
