[SOLVED] Writing to an output file in VHDL
MSAKARIM
Full Member level 3
Full Member level 3
I'm trying to write some data to an output file in VHDL but i have this error during SIMULATION step :
" ** Failure: (vsim-4) ****** Memory allocation failure. *****
# Attempting to allocate 2147483664 bytes
# Please check your system for available memory and swap space.
# Time: 0 ps Iteration: 0 Process: /padtofile/line__30 "
My code is:
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.NUMERIC_STD.All;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
USE IEEE.STD_LOGIC_TEXTIO.ALL;
USE STD.TEXTIO.ALL;
entity Padtofile is
generic(          block_size    :  integer      := 1024;    --bits
          length_bits   :  integer  := 128  );--bits
port(message: in std_logic_vector(63 downto 0));
end Padtofile;
architecture Behavioral of Padtofile is
signal clock,endoffile : bit := '0';
signal    linenumber : integer:=1;
begin
clock <= not (clock) after 1 ns;
process
variable mod_val: integer;
variable padding_length : integer;
variable padded_length : integer;
variable message_length: std_logic_vector((length_bits - 1) downto 0 ) := (others=>'0');
variable padded_message: std_logic_vector ((padded_length - 1) downto 0) := (others => '0');
Variable padding: std_logic_vector ((padding_length) downto 0) := (others => '0');
file      outfile  : text is out "Pad.txt";  --declare output file
variable  outline  : line;   --line number declaration
begin
--padding message
mod_val:= (message'length) mod block_size;
padding_length := ((block_size-129)+(block_size - mod_val));
padded_length := ( message'length + (1 + padding_length) + length_bits);
message_length := std_logic_vector(to_unsigned(message'length,length_bits));
padding := "1" & std_logic_vector(to_unsigned(0,padding_length));
padded_message := message & padding & message_length;
wait until clock = '0' and clock'event;
if(endoffile='0') then
write(outline, padded_message, right, block_size);
writeline(outfile, outline);
-- write line to external file.
linenumber <= linenumber + 1;
else
null;
end if;
end process;
end Behavioral;
Here is your problem
Edit----------
What probably happening is your computer is struggling to create the std_logic_vector padding, because it's such a mammoth size your local computer/software cannot create a register to capture that std_logic_vector
padding_length is an integer with no initial value. So will be set to -2^31+1 (same with padded_length). It means your message_length and padded_message and padding arrays have a 0 length (because they are null arrays). But this wont be the problem.
You're then trying to assign some very long stvs to these null arrays.
I also not you're using '87 style file declarations. The '93 declaration style is:
file f: text open WRITE_MODE is "some_file.txt";
Im not really sure what you're trying to do
