garvind25
Full Member level 3
I was writing test benches of VHDL codes (in VHDL) and came across a problem. I hope someone can help me.
While writing test benches for small number of inputs (say two or three one-bit inputs) I am able to cover all the case (four or eight cases). But when I have big sized inputs (or a large number of them), I am having difficulty. For eg. for testing a 8 bit adder which adds two 8-bit numbers, I will have to manually enter 2^8 * 2^8 input combinations (and off course the correct answer accompanying each test input pair).
Is there any other way to do so? Is there any way to automatically generate the 2^16 inputs? Also how to go about mentioning the corresponding outputs in the test bench?
Looking forward to your responses.
Thanks in advance,
Arvind Gupta.
Thanks in advance,
Arvind Gupta.
