write into mmc (memory card) from pic
adm1
Junior Member level 1
hi all,
i am a beginenr in pic programming, and i very urgently need to know how to write data from a pic port into a mmc... i have very less idea abt mmc and pic programming.. i am using a pic18f45550 controller in order to do this.... but am not getting idea how to start the process....it would be of great help if anyone could give a sample code / proteus simulation of data loggin into mmc.....
help will be greatly appreciated
thank you
hello guys!!
anyone knows how to write into mmc from pic!!.... i need to knw it urgently
i am using a pic18f4550... i have interfaced an rtc ds1307 with it, now i need to write that time into a memory card ?? ,...i m really stuck.........how do i go about doing it ?...i looked at the examples in mikroc..but cud not understand anything frm it
hey, i m also doing project using pic and ds1307. if you have program for rtc and pic interfacing using instructions and not in c-language then plz reply on my email
parag290@gmail.com
hi parag... i have the code in c.. but there are c compilers that allow you to convert c prog to assembly... check ur mail
hi....
i have a need to design blood pressure devices using the PIC16F877, in my case, the data is need to be save in the memory card, but i don't have the code to write the data into the memory card..
can somebody help me?
this is my email : manjung_4@yahoo.com
thanks for all your help..
hi
i am doing a project on PIC18f2620 that capture images and store the data into sd card through SPI and i am using sdcc compiler, may i have your code as reference coz i am stuck on how to create a file and write data into that file in sd card.
Thanks,
email:snsdforever@gmail.com
you guys can try MikroC IDE, it contains library function for using SD card. and also contains a sample program !
its easy !
how can i copy {master}mmc to other extention mmc [at lest 20 pcs mcc ] via pic micro controller
pl help me or PM me. for other detial
