Wrapping Burst.............refers to what in AMBA....?
Guru59
Full Member level 4
Full Member level 4
wrapping burst
thanks
burst wrapping
incase of wrapping burst, when the transfer has reached its max. limit, it loops back to the lower address.
wrapping bursts
Total burst size in bytes is determined by HSIZE * HBURST. If the starting address in a burst (HADDR) is not a multiple of HSIZE*HBURST (i.e. aligned), and wrapping is used, then the address will increment until it hits a multiple of HSIZE*HBURST then wrap around to the previous multiple of HSIZE*HBURST.
burst wrap
in short, wrapping here means going back. The haddr will be back to its start address when the boudary is reached.
what is wrapping burst
example:
a wrap-4 burst transfer, 32bit size for one beat, first address 32'h0000_0001, the transfer will be as following:
word 1, address 32'h0000_0001;
word 2, address 32'h0000_0002;
word 3, address 32'h0000_0003;
word 4, address 32'h0000_0000;
that's it!
wrap burst
can any one explain it for hword starting at 32'h0000_0002;
Thank You...
Kushagrak
amba incr burst aligned boundary
The wrapping is clearly explained in the protocol specification. One thing you have to take note of is that the address should be aligned and cannot start at a random address.
All transfers within a burst must be aligned to the address boundary equal to the size of the transfer. For example, word transfers must be aligned to word address boundaries (that is A[1:0] = 00), halfword transfers must be aligned to halfword address boundaries (that is A[0] = 0).
So if you are performing word transfers you cannot start at an address with A[1:0] = 10 or for that matter any thing other than 00
    V
what is wrapping burst?
HADDR[1:0] = 00 for word transfers,
HADDR[0] = 0 for hword transfers,
what about byte transfers............?
Thank You,
KUSHAGRAK
Re: what is wrapping burst
example:
that's it!
Please explain how addresses are increasing by unity? why not by 4 as it is word transfer?
