komplex
Newbie level 3
- Joined
- Sep 4, 2011
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- South Africa
- Activity points
- 1,316
Would you please have a look at my calculations to see if I’m on the right track
Hello.
Would you please have a look at my calculations to see if I’m on the right track as I don’t really know which values to use in the datasheet?
I want to drive an h-bridge with TIP 140 power transistors, View attachment TIP140 .pdf.
So the idea is to turn the transistor on by applying the correct base current Ib while I know what my collector current Ic is and I’m using 5V from a pwm as base voltage Vb.
Ic = 5A
So
Ib = Ic/hfe
hfe is found in the datasheet to be 1000 at Ic = 5A.
Ib = 5mA
And then
Rb = (Vb - Vbe )/ Ib
Vbe is taken as 3V from the datasheet.
Rb = (5V – 3V )/ 5mA
Rb = 400ohm
Is this how it should be done?
If I want this transistor to turn on and off as fast as possible or to make it move across the active region to saturation as fast as possible should in not just make Ib swing from 40mA to -40mA to keep ton and toff to a minimum like it is shown in the datasheet?
Hello.
Ic = 5A
So
Ib = Ic/hfe
Ib = 5mA
And then
Rb = 400ohm
