dl09
Full Member level 4
i found this equation on the internet 2 × √ ( i/n × π × a) for calculating the gauge of both the primary wire and secondary wire of a flyback converter. i is effective current, and n is number of turns, a is current density, and the article said pick 4 amps per millimeter squared to 8 amps per millimeter squared. would an engineer actually use this equation?
