krishnakumar.r93
Member level 2
Hi all,
I use Proteus ARES for my PCB designs. When i use a polygon for a ground plane and export the layer as pdf, i get lot of vertical lines in the polygon area instead of solid fill. When i zoom in/out, the vertical lines disappear and i get a solid fill. But when i outsource in to my manufacturer for fabrication, i still get the vertical lines on my board instead of solid fill. There is connectivity, but i feel the plane is weak. Will this vertical lines weaken the ground plane of my circuit?
I have attached the model images of the problem i have. Somebody help me out ASAP.
