Working of a Voltage Tripler(use of Rectifier Diodes and polar capacitors)
Shayaan_Mustafa
Full Member level 5
Full Member level 5
Hello experts!
Here is a voltage tripler circuit attached. I want to know the working of this circuit. Assume the circuit is grounded and diodes are ideal i.e. they will not drop any voltage across them typically 0.7v.
STEPS:
1) When a -ve cycle comes, D1 activates and C1 charges to peak voltage(Vp) ideally. While other diodes remain off and no other capacitors will charge.
2) When a +ve cycle comes, D2 is activated and as C1 is already charge, (C1 discharges in this step through D2), so source peak voltage and C1 voltage charge C2 to 2Vp.
3) When again -ve cycle comes, D1 activates and C1 charges to Vp. As C2 is already charged then it will activate D3 and allows C3 to charge upto the voltages that were hold by C2 i.e. 2Vp.
FINAL:
Output will be taken across C1(Vp) and C3(2Vp). Hence, we get 3Vp
Is this all working correct? Help me so that i could design a voltage multiplier that gives 5 times output of voltage source.
Thanks.**broken link removed**
Thanks for reply goldsmith.
Cockcroft-Walton generator or multiplier is an application for which that i have posted.
So therefore I need a discussion on the topic and I posted it here.
Kindly discuss it here. Tell me working is correct or where I did wrong??
Thanks .
The circuit is correct.
You can extend it by duplicating the right side block comprised of two diodes and two capcitors and adding it to the right side. Due to the series connection of capcitors, the output resistance will increase however, you get more voltage and less current.
Again Hi
And sorry for delaying to reply .
Yes , i'm agree with FvM . and your circuit is correct . and about current if you increase the capacity of your capacitors , the current can increase , but the valuse of capacitors won't be reasonable for high currents . and for higher currents , you'd better to use a simple Boost converter .
Best Wishes
Goldsmith
@FvM and goldsmith.
From circuit you mean my steps are correct?
Did you read steps for circuit operation carefully?
You have been asking, if the circuit is working. That's the case.
The operation description is basically O.K., but not exact. I don't agree to the sequential step description. It takes more than three "steps" to charge the capacitors fully.
fully.. but above I mentioned that assume diodes are ideal so the capacitors will charge to the peak values in each cycle.
@FvM. Will you justify the bold statement quoted above? Please.
The output voltage is approaching the final value in a geometric progression, because the capacitor charge added in each input voltage cycle is divided between multiple capacitors. You'll noticed that the charging process becomes slower if more capacitors are involved.
  • Voltage Multiplier.zip
This multiplier is a cascade (or Villard) type. It consists of three diode-capacitor pairs, each of which is referred to as a Villard cell.
I will make an animated simulation of this tripler (along with 1 or 2 others). I'll plan to put the video on Youtube in a couple days.
@FvM
Thanks I got your point. And want to ask, which simulator did you use? Name please.
Thanks.
---------- Post added at 20:05 ---------- Previous post was at 20:05 ----------
Thanks BradtheRed. I am waiting for your response.
Is it better than Multisim or Altium designer?
Hi again
Surely yes , i think . because the spice series are more close to the real than the others.
Good luck
Goldsmith
