Work TComPort Library 2.63 into C++Builder 6?
bomba
Full Member level 2
Full Member level 2
tcomport c++ builder
Somebody test this component into C++Builder 6. Tell me if it works.
Could you recommend me the best free component available for serial communications?
Thanks in Advance
tcomport builder
Tcomport is very good for a free component and,I use Tcomport with delphi without any problem,I think that with "Builder" it's the same.
Otherwise you can use "Asyncpro" he is free now
tcomport c++
I THINK THAT THERE IS A RELEASE WHO WORK FINE IN BULDER 6.
FIND IT.
BYE.
work with tcomport component c++builder
Could anybody post the TComPort official site link ?
Check it.
Thanks
tcomport delphi
The official site seems to have disappeared. You can get it from
-who wrote the C++ Builder port for this excellent library. I have used it with Builder 6 and it works, though there is a slightly tricky process to install it. This is described in the files.
Is it work with Win XP (Base on delphi).
It works with Windows XP when programmed with C++ Builder 6.
I would expect that it would work with Delphi since the library itself is delphi based (as well the the entire visual component library (VCL) of C++ Builder).
The project is now part of sourceforge and has been ported to Delphi 7 as well.
For more info:
https://sourceforge.net/projects/comport/
