You need to open a terminal in a linux system. There is a lot of programs to open telnet or ssh session (teraterm, putty, secureCRT...). You only need one of this programs and the IP address of the linux system.
Using exceed in Windows, you could connect the PC to a Unix server, such as Linux, Solaris and so on. The only problem is to increase the computation burden in the server.
