vilfred
Member level 1
I am working with wiz110sr serial to Ethernet converter, there i got confused with configuring IP address in wiznet configuration tool.
What IP address should be in the local IP option in configuration tool?
I can't able to connect my WIZ110SR module's network terminal with serial terminal. I have used static mode in that i assign the local ip from command window ipconfig in my PC, and i give default port number. Then i select mixed mode and after complete setting i upload the firmware file, after my firmware upload successful i opened device terminal window there i set the same ip address and port number from configuration tool(local IP)in network terminal and press connect, and open the serial terminal. There i got error message as can't open socket. Please point out my mistake.
