[SOLVED] wiring pull-up resistors on i2c device
s7nf
Newbie level 1
Newbie level 1
Hi!
I'm trying to figure out how to wire the pull up resistors to STLM75 (digital temperature sensor) .The datasheet is in the attachment . On the p. 11 you can see connection diagram.
Now I don't know how to wire SCL and SDA pins. Should I wire each resistor separately to Vdd? Because inthe diagram they are connected together.
  • CD00153511.pdf
One end of the resistors will be connected to the positive supply , you can either connect them individually to Vcc or connect them together and use a wire to Vcc , in either case the result is the same , both ends are connected to the same supply which means that they are also connected between them.
Alex
Reactions: s7nf
    s7nf
