Externet
Advanced Member level 2
- Joined
- Jan 29, 2004
- Messages
- 603
- Helped
- 28
- Reputation
- 58
- Reaction score
- 30
- Trophy points
- 1,308
- Location
- Mideast US
- Activity points
- 6,010
Hello all.
A magnetic loop antenna used in very wide band 50 to 600MHz reception has two ends. None is ground. A coaxial cable attached to the core on one side and a shield on the other.
At the receptor end; the shield conductor is connected to the front end chassis.
The same loop antenna for reception... If the loop ends are connected to a 'bal' side of a balun and the 'unbal' end of it to the coaxial ending at the RX front end.
What should perform better, without or with a balun ? Which is lossier ?
Loop========================coaxial===================>receiver
Loop+balun===================coaxial===================>receiver
