Ameera Q
Newbie level 3
![Newbie level 3](/styles/images/ranks/alevel3.gif)
Salam everyone,
I'm new to the forum, I'll try to explain my problem step by step:
In my verilog code I have one top module and one sub module that is generated many times using generate for loop, the output of one sub-module is an input to the next,
These I/Os is declared as array of wires in the top module and I'm passing for example wire as input and wire[i+1] as output. each wire is a vector of let us say N bits.
Inside the sub-module the input is converted to 2D array and used to produce a 2D array reg that is converted to a vector and assigned to the output.
my problem is that the value of OUT is updated but the value of W_OUT is not updated until the next CLK :sad:
W_OUT is a wire it should be updated immediately as far as I know. So why it isn't updated immediately ?? Is there something wrong with the assignment ??
Thanks in advance.
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 //this is not my actual code but it is exactly what I'm doing module sub (CLK,E,W_IN,W_OUT); input CLK,E; input wire [N-1 : 0] W_IN; output wire[N-1 : 0] W_OUT; wire [W-1 : 0] IN [0 : N/W]; //2D array for input reg [W-1 : 0] OUT [0 : N/W]; //2D array for output //generate loop to convert from vector to 2D and vice versa genvar i; generate for (i= 0; i< N/W; i= i+1) begin :loop assign W_OUT [(i+1)*W-1 -: W] = OUT[i]; assign IN[i] = W_IN[(i+1)*W-1 -: W]; end endgenerate always @(posedge CLK or posedge E) begin // rest of code manipulates OUT
Thanks in advance.
