darkfall94
Newbie level 6
hello, my project is wireless door opening alarm...its taken from efy aug 2014 edition.
here's the ckt with transmitter and rec.
here are some of the changes i made:
1. instead of reed switch, am using 2 open wires to act as a open and closed switch as req
2. using 1 more led instead of peizo buzzer (no particular reason)
3. instead of using dc battery, am using psu from my lab
but the ckt is not working. I even tested at the ''test points'' as portrayed in the schematic; everything is proper.
just instead of getting 40Khz at TP3,TP4, i get some 35-36 Khz.
and instead of getting 80Khz at TP2, i get around 75Khz.
what could be going wrong?? the led's are fine.
any help would be appreciated!
PS: I have faith in this ckt coz its "efy tested"
